Fuse box
Started by nick Godridge, July 23, 2015, 17:04:31
nick Godridge
Hi all, I have tried to add pics to illustrate my question.
   But anyway here go'es wih the problem.
   Simply put the fusebox diagramme in my Manual bears no relationship with the actual fusebox, so I am struggling to figure out which fuse is which.
   Just in case my pics are not there, my cars box is laid out as follows.
   5 relays in a side to side row at the back.
   2 groups of 6 fuses, placed side by side, with fuses orientated front to back,all in front of the relays.
   Each group of 6 fuses has a separate clear plastic cover.
   My car is late '84 build chassis 1035.
   Dos anybody have a manual showing an early fusebox?
Flyinghorse
Nick,
   Hopefully someone will front up with a diagram. The layout sound similar to the one on my CRS passenger footwell.
   I had a similar issue with a series 2 landrover I had to rewire and most of the colours conform to the Lucas Uk wiring code.
   Not sure if Ac did the same:
   //http://www.mgb-stuff.org.uk/colourcodes.htm//
   I would simply remove each  fuse to see what it operates and label them up myself.
   I hope you wont need a replacement lucas smoke kit:
   //http://www3.telus.net/bc_triumph_registry/smoke.htm//
Originally posted by FlyinghorseI hope you wont need a replacement lucas smoke kit:
   //http://www3.telus.net/bc_triumph_registry/smoke.htm//Graham
   So do I as that kit is only available in Whitworth, and ALL MkIV`s are metriculated!!! [;)]
nick Godridge
Interesting wiring info Flying Horse.
   Will check it out against my car tomorrow.
   Nick G
Here are Nick`s photos of the Manual:
   ...And the reality:
