Looking for starting handle engine bay Terrys clip
Started by SpqrEddie, December 11, 2022, 00:10:01
SpqrEddie
Hello!
I am looking for an original engine bay starting handle Terrys clip.
anybody has a spare one for sale?
thanks!
This is the closest newly available "Terry" clip. The only real difference is the design change to a single rivet style
as the original double rivet clips often crack across the rivet holes.
The normal size for an AC starting handle is 22mm.
//https://www.ebay.co.uk/itm/252046159080?_trkparms=amclksrc%3DITM%26aid%3D777008%26algo%3DPERSONAL.
SpqrEddie
Thank you Klassik Metall!
i have ordered them.
Eddie
SpqrEddie
#3
Hello I would like to report on the 22mm "Ebay" Terry's clip.
they are very similar. I belive as well the original were black. on the back of the broken one i found trace of black paint.
The Ebay one has the same distance between holes and the same holding diameter.
The wings have the same shape, and the platform as well.
The only difference are the rivets, the new one has only one.
Sorry for the rivets counters! but with the starting handle in place you should not see it! ;-)
