Forum Issues
Started by administrator, June 25, 2024, 07:57:43
After a series of problems with the Forum, our providers have rebuilt it with the latest version of the software. hence the different look.  Everything I have tested so far works fine, but please let me know of any issues.
Bryan
paho
Well Done!
login works fine now. Search function works fine when logged in. But the captcha verification text is very small and incomplete, one needs to play the letters and then insert to activate the search feature, see attached screen dump.
BR/Paho
P.S Received this notification when attaching picture:
"The message has the following error or errors that must be corrected before continuing:
    There was a problem and your attachments could not be uploaded
    The attachments directory can not be located. Please notify an administrator of this problem."
Big col
It looks good. 👍 can we do emoji's ? Yes I know I have one here but it came up on the top of the keyboard, not self selected.
I might be rough but I'm slow as well.
Cant seem to uploads pics, same message as Paho. What happened to the bit at the bottom that we used to have.
Hi has anyone found out how to put photos on here. Cant seems to get it to work.
SunDude
#5
There is an icon (just right of the YouTube icon) that allows you to hotlink an image from another hosting site, but I don't see anything that allows you to directly attach/upload an image.
The bar just below the reply textbox that says "Click or drag files here to attach them." doesn't seem to work. It gives an error message saying to contact the Administrator. Not sure what the problem is.
TTM
"The attachments directory can not be located. Please notify an administrator of this problem."
The hosting option is probably ticked off for now as a matter of data volume management?
Thanks - will chase that up with racecar.
Looks like this has been fixed.  You have to select your file rather than using 'drag and drop' - I'll see if we can get that working as well.
Hi Admin.
Yep it works a treat.
