Cobra Ball Joint Rubber Boot
Started by rr64, February 10, 2009, 22:50:52
rr64
The image below is of the ball joint parts from a Cobra. One of the parts in the assembly is a black molded rubber dust boot (under the stop nut in this image). These boots are often in bad condition or missing all together. The only service part I have found through Cobra parts dealers in the USA are made of an almost clear translucent plastic that seems to be fragile or ones molded in black rubber that are about 125% larger and might be some type service part for tie rod ends.
   Does anyone know of a source for the Cobra size molded rubber service replacements for these rubber boots? Thanks for looking.
   Dan
Dan Case
Check with Kirkham! www.kirkhammotorsports.com/ I have found that all their suspension parts fit!
rr64
Dan Case
