Aceca Tools
Started by pjbowman, January 18, 2009, 22:51:27
pjbowman
Does anyone happen to have a picture of an original, correct Aceca (AC-Engined) tool board with the correct tools? I can't figure out what two of the slots are supposed to hold, and the factory parts list doesn't clue me in either.
   Peter B.
Peter B.
59 Aceca
Peter,
   Here's a photo of an original tray including its tools + a nearly complete duplicate set sourced from ebay.  If you have any specific questions, just let me know.
   Greg
pjbowman
Great, thanks Greg. What are the two tools at the bottom of the picture, the oblong thing with the hole, and the tool below it? Also, how long are each of the following:
   - screw driver
   - tommy bar
   - spark plug wrench
   Don't know where I'd turn without my friends here on the forum!
Peter B.
59 Aceca
Peter,
   I believe the two tools you're referring to are a brake adjuster and brake bleeder.  The photos below will show you what they look like.  I need to find them for my tool kit as well.  The complete kit belongs to a fellow Aceca owner and club member.  It was invaluable in sourcing my own set, as well as in making a reproduction board (still needs its flocking applied).  Ron Leonard will carry reproductions of both brake tools at some point but is currently out of them.  As to dimensions:  The screw driver is 8" long, the tommy bar is 6" long and made from 5/16" rod and the spark plug wrench is 4" long.
   Ebay is a great source for the tools, although I'm still looking for the brake adjuster and bleeder in the above photos. Good luck!
   Greg
pjbowman
Perfect, thanks Greg. At least now I know what to look for! As always, your invaluable help appreciated.
Peter B.
pjbowman
Greg - can you send a couple of pictures of the bleeder and brake adjuster looking down on the 'business' ends of the tools so I can see the shapes? I'm thinking of just making up a set for now while I (like you) look for originals. They don't look too hard to weld up if I can figure out how to make the 'tube' portions of each. Thanks for the help.
Peter B.
59 Aceca
Here you go, Peter.  Happy to help.
   I'm pretty sure that the larger tool had a 3/16"W socket and the smaller a 1/4"W socket.  Cannot really verify as I no longer have the tools...only the photographs.
   Greg
Aceca289
Hi Peter,
   The complete tool set Greg is referring to is out of my car. I will measure the size of the brake adjuster and the brake bleeder with a caliper and post the measurements when I have time. I am not quite sure the "brake bleeder" tool is actually used for that purpose since it does not fit the bleed nipples on my brakes; although, I thought it might be for that use since the bleed nipples on the rear breaks are so hard to reach (I think the original bleed nipples have been replaced on my car). Does anyone else know about the intended use of this tool (the hex socket tool)?
pjbowman
Thanks Greg and John, that will be great! Between the pictures and the drawings, I think I can make up some close approximations. The original parts list doesn't even list either of these tools for the AC-engined Ace/Aceca. For the Bristol bretheren, it does list a 'Brake Adjusting Spanner', a 'Cylinder Head Ring Spanner', and a 'Cylinder Head Box Spanner', maybe these items area actually examples of 2 of these 3????
Peter B.
pjbowman
John - does the tool with the hexagon socket maybe fit the acorn nuts that hold the valve cover in place on the AC engine?
Peter B.
pjbowman
John/Greg - on the 'bleeder' tool (flatbar handle, square socket opening), does the 'socket' start out as a round tube welded to the flat bar, and then flare to the square end? Or is it square tubing all the way?
   Thanks guys.
Peter B.
Aceca289
   Thanks guys.
   The flat handle square socket opening tool is definitely the Brake adjuster spanner (used to adjust the rear breaks...have used it many times to adjust my rear brakes). The socket starts out as a round tube and goes to square. It appears to have been made by heating and forging it square at the top.
   I will e-mail you a PDF of a sketch with dimensions (of both tools) and I will scan it into a jpg file and see if Greg can upload it to the Forum for everyone else as I have not taken the time to figure how to upload to the Forum yet.
Aceca289
   The hex socket spanner is what I thought was used to bleed the rear brakes, but I don't think it is for that use since it doesn't fit the bleed valves. There has to be another AC club member who knows what this tool is used for. I will drop this tool off to Greg to see if he can determine if it fits any obvious parts on an AC engine. My car was an AC enigned Aceca (AEX521) before being converted to a 289.
pjbowman
Wonderful John, thanks. And thanks for the detailed drawings! They are just what I needed.
Peter B.
GaryC
I used that brake bleeder on BEX402 and it was definitely designed to go thru the rear emergency brake housing that sits over the bleeder. Saved hours of pain. Gary
