On the dyno 19/3/08
Started by mossfred, November 06, 2008, 13:39:46
mossfred
Doesn`t look very exciting but so loud it scared everyone out of the dyno room! http://uk.youtube.com/watch?v=ywO-V5aMC6Y
Mark-Anthony
Fred,
   You're mad!
   Mark-Anthony
   CRS #22
mossfred
You wouldn`t be buying a Cobra if you were sane!!
dart427
Hi Fred,
   please tell me more about the engine.
   Horst
mossfred
What would you like to know?
dart427
Hi Fred,
   Did you chose the factory block? Or an extra strong aftermarket version with forged internals for your powerplay?
   Horst
mossfred
Horst,
   We used the stock block  with stud girdle, Probe superlight pistons scat forged rods and stock crank. Stock block is ok for 450 ish hp as long as you dont rev the motor too hard, in normal use i only use 6000 rpm. It was making more power at 6600 but was already  running lean as the injectors (42lb) were open  (maxed out). Heads are ported TFS twisted wedge with about 310 cfm on the intake and 210 cfm on exhaust, custom grind roller cam and holley systemax II intake. Vortech T Trim at 13 lbs. It will probably disintegrate soon!
   Fred
dart427
Fred,
   very interesting. Thank you.
   Horst
