2 Litre brake bleed advice sought
Started by Chris Hartley, February 24, 2017, 16:42:37
Chris Hartley
I need to bleed the 4 wheel Girling hydraulic brakes on my 1955 2 Litre but am unsure what type of fluid to use. Clearly the days of 'Girling only' oil are long gone and I will have to use a universal fluid but these days there is a bewildering variety available for different applications which did not exist in the 1940s/50s. I have plenty of Comma DOT 4 synthetic fluid available.  Would it be suitable?  Advice please, as I don't want to damage anything.
Hi  Chris
   I use dot 4 synthetic as well. However, I would suggest you do flush all the old fluid right out of the system first, I did this with an old reservoir cap and fitted a tyre valve then used a foot pump to purge it all out, open all the bleed valves and use some small rubber hose into jars. Refill with new fluid and I did it once more with the new fluid to make sure all the old fluid had been washed through, it does waste that much fluid, then I refilled it with the bleed valves open to make sur the fluid started to run through and my able assistant watching we tightened the bleed vales topped up and bled the system in the normal way.
   Hope that makes sense.
   I will be doing the same again soon, once my engine is back in car.
   Good luck
   G
Chris Hartley
Many thanks G!  I thought the DOT 4 would be OK, but needed someone to confirm to give me full confidence. Car in garage. All wheels off.  Adjusters locked up.  Fingers crossed!
Hi Chris  No problem, hope they bleed out ok.
   G
