AC Ace Clutch - Parts for clutch Actuation
Started by UFR131, May 31, 2016, 14:37:57
UFR131
Hi - I have a 1960 AC Ace with the Weller engine and have some badly worn parts on the clutch actuation that has led to the push rod that fits into the clutch cylinder shearing and hence car unfortunately off the road at present.  The parts that I need to replace are the clutch actuation lever that is mounted on the side of the bell housing together with the ball type cylinder push rod end fitting that fits into this lever. Can anyone advise where I can get these parts ?
   Thanks for your help,
   John Bonafoux
3.8Jaguar
These I re manufacture to need, I should have patterns to copy but to be certain that your is correct can you post or send photo with a couple of basic dimensions . cavcont@outlook.com
UFR131
Thanks for your reply. I friend has managed to machine up an new push fit insert for the actuation arm and matching cylinder rod end fitting so all sorted now and car back on the road.
