Car No 6199 1921
Started by jonto, December 02, 2015, 18:21:25
jonto
Sometimes it seems you have taken a step backwards-
jonto
It feels like your doing a fitting for a bespoke suit-
jonto
Still a lot to do, shaping up, beading.
jonto
jonto
jonto
Quote from: jonto on December 04, 2015, 13:36:31
Headlamps from this car have adorned the front of 31225 for the last 40 years-
   The pistons have no oil rings, two substantial compression, then a groove with drain holes-
   The residue of the oil in the sump stuck to your skin like tar, almost impossible to scrub off!
   The valves have no guides, run direct in the iron block, unequal stem diameters, the inlets larger than the exhausts, perhaps Anzani's were using up old stock left over from their cancelled aero engine contracts. The amount of carbon deposit under the exhaust valve heads had to to seen to believe! Bit plasticy to not hard, benzol based fuels were popular I believe, not the volativity of today's fuel. I remember a picture of Birkin filling his Alfa during a TT, would be 1931 I guess, big funnel in the tank, emptying a churn into it, fuel sloshing all over and he has a fag in his mouth!
jonto
Done a bit more, beading to the panels, running boards and spare wheel mount, though I'll need more timber for the boards, dimensions are a bit guess work first try!
jonto
Update, no so much to do now, I have some rear wings I can use, but no stays, conversely, I have the stays for the fronts, but no wings   :)
jonto
jonto
Update, the bodywork is not far from completion now, I am currently working on the mudguards.
jonto
Great looking machine, she will be loads of fun
jonto
A bit more progress. The early type windscreen and CAV "Torpedo" lamps.
Old Crock
It's coming along Jonto!
Something to be very proud of - well done
