steering column
Started by French Frie, December 28, 2011, 15:49:54
French Frie
...BTW, has someone already tried to remove the black paint on the gauges bezels ? when I loook at the clock, it looks like it is chrome behind, but can't be sure ... anyway, new chromed bezels can easily be found on Ebay, but if  paint has only to be removed, it's even easier !
I removed the black paint on the bezel of the round control light unit with thinner. Underneath there is a stainless bezel. I polished it with a Dremel tool and it dosn 't look so bad.
   I will come up with pictures as soon as my straight dash is back from the saddler. I removed the paint from the control light unit only because it will replace the rectangular plastic light panel.
   Uwe
I was adjusting the paddle mechanism on my CRS steering column today and could not get it to tuck away cleanly into the slot in the plastic moulding when tightened on the cam machanism-kept fouling my leg. (RHD paddle on left side when sitting in the car)
   I sorted the problem by rotating  the paddle lever - putting it in the foot box side toward the engine  for adjustment--ie 180 degrees out.
   Would be interested to know if other owners can get the adjustment paddle to function correctly & stow cleanly in the "correct" position.
