Mark IV Invoices/forms/etc.
Started by Mark IV, January 01, 2007, 19:38:56
TLegate
30 quid!!? I must have been looking in the wrong place last year! Mind you, as I live a stones throw from Gatwick, I tend to forget there are other airports. No cheap flights from there though, so I put it on the back burner. Curses
cobham cobra
But Stelios has re-named it Luton/London so it can't be that far away .....can it ? I might be interested in an ACOC weekend in Malta. Given that the weekend forecast in London is snow, Malta sounds good. Is anyone else interested ?
   John.
SB7019
John.
   At £30 for a flight it sounds like a good idea!    I'll look on the web to see if there are any good hotel deals.  What sort of dates did you have in mind?
SB7019
Cheapest 4 Star I can find starts at £14 per night!  At that rate it's less than the cost of me staying here and heating the house - must make sure Jean has a warm coat!
cobham cobra
SB7019
Just in case you may think I have lost my senses and have suicidal tendencies I did show the post to her and got full permission before I sent it.
cobham cobra
Well, yes the thought did cross my mind. Do you have to obtain permission for each contribution or do you just submit a report to management at the end of the day ?[B)]
SB7019
Our policies dictate that normal day to day communication can be undertaken without prior approval, though is subject to random audits.  However items that may be considered of a sensitive nature do require concurrence by the appropriate authority.  Failure to adhere to these policies can lead to serious censequences and would have certainly led to the withdrawal of priviledges such as the magnificent Filet de Bouef au Poivre that I have just enjoyed.
Lewis AK1069
was 1069 originally white it is black now?????
Lewis AK1069
Hi mark ,do you know why this car had a color change
ak1234
I dont think after the car was delivered in white anyone here would know why it was painted black ..your best bet is too take the info and contact the original owner .. I dont think you will egt the answer your looking for.
   Ron
westcott
Hi Rick,
   are there any records about AK 1106 available in your knowledge base?
   Thanks, Uwe
Alan Faulkner-Stevens
I still have the master pattern to produce "fastback" style hard-tops if any owner needs one. Custom fitted to your individual car, so perfect fit. Highest quality top which uses all factory positions for easy, no modification, location.
marklotus
Can anyone tell me or show me what type of weatherstrip/molding is at bottom of hardtop, where it sits on the body of the car? What are measurements and profile so I could try to find or replicate?  Thank you.
Mark IV
Originally posted by westcott
Hi Rick,
   Thanks, Uwe
   I will look and report.
