MkIV throttle cable
Started by koen, August 25, 2011, 16:59:29
koen
The MkIV of one of my friends had a melted throttle cable surrounding, which causes a sticky throttle cable at 4500 rpm.
   Very dangerous.
   I want to replace the complete cable now, but can anyone tell me
   if there are safer ( I mean with non-melting materials) cables available please ?
   Koen.
If you have time build a linkage with rod ends:
   Very precise.
If you don't want to go with Peters linkage have a look at Lokar, they have universal braided stainless cables and dipsticks with aluminum fittings and teflon inner tubes. If the wire is damadged one day you can replace it by a standard bicycle brake cable, because the Lokar fittings are screwed.
   See here:  http://www.lokar.com/product-pgs/throttlecables-kickdowns/tc-kd-main.html
   Uwe
Gus Meyjes
Go with the linkage! plus a couple of return springs for safety. It is not that difficult to fabricate, very precise and no melting business!
koen
Thanks for all the input. In the end we decided to go for the linkage.
