correct tire pressure?
Started by gblue, December 27, 2006, 20:49:25
gblue
Aloha....what is the correct tire pressure back and front..can't find it anywhere..my backs are 25 and fronts are 26.5.........thanks
Use 30 PSI front and rear. you can adjust it up or down a couple of pounds to balance handling. Be careful on the old Goodyears, they get very greasy as they get old.
   Rick
   Rick
   Gregg, Rick is referring to COLD pressure sets. But the optimum is on the tires sidewall. Then check the wear pattern and adjust from there. Jim
MkIV Lux
   Hi.. just see the first of the pics that you have posted on your new car. All info is there.
   Happy new year
   Constant
gblue
thanks....it was right in front of my eyes.......
