clutch replacement
Started by jbottini, May 10, 2010, 15:05:23
has any one done a clutch on one yet? I am led to believe that the trans tunnel must come out versus doing the repair from the bottom. athoughts?
Hi Jim,
   I think it depends an the transmission. In my case there is nearly no space to shift the transmission to rear. So the good news: no, you don't have to remove the trans tunnel [:)], because you have to remove your engine [B)].
   But maybe any of the professionals have a better hint.
   Best regards,
Peter,
   Thanks for the personal knowledge...I'm afraid its one of the two, hopefully someone has found a secret...like remove shaft rotaote trans 1'' to right after disengaging from engine and clutch plate will slip right in..but I doubt it.
   Jim
