steeringbox
Started by mau, November 10, 2009, 23:16:24
mau
I have play on the steeringwheel.
   Anybody can tell me the tolerance?
   I adjusted, following the manual the secured bolt on top.
   Still there is some play.
   What is next to do?
   Looking for advise and somebody hopefully in the Netherlands that is capable to overhaul.
aex416
Bishop Cam steering box or rack and pinion?
aex416
wheel camber, 1-2 degree positive; wheel toe-in on rim, 1/16 in; castor angle, 5 degree; king pin inclination, 9 degree ( per Rinsey Mills book )
mau
Thank you
   The steeringbox is bishop cam definitely not rack and pinion
aex416
If you can get your hands on a copy of Rinsey Mills book on AC Ace, Aceca & cobra it may be of some use. Try Amazon! If you would like I could scan an owners manual page regarding the steering.
