Brake pads
Started by Ian Rogers, June 09, 2009, 21:45:39
Ian Rogers
Can anyone enlighten me as to the brake pads used on the early Superblowers. The early SB's were effectively MK IV's that were uprated. The car I have been asked about is the first AC produced car fitted with a supercharger - 1997. Mine (1999) is fitted with AP Racing brakes but were these fitted to early SB's or indeed MK IV's per se. Thanks in anticipation of your enlightenment.
AK1185
I also need front brake pads.  I understand they are 1980's BMW but don't know the year or model BMW. Please help. Thanks.
ANF289
   According to Peter (aka dkp_cobra) the front disc brakes should be BMW E23 from years 03.77 - 07.86. The original part number from ATE is 13.0460-9031.2
That' correct. Please have a look here:
   ATE online catalogue
ANF289
   You have to start here:
   http://www.ate-na.com/generator/www/us/en/ate/ate/themes/60_online_catalogs/20_european_online_catalog_tecdoc_us.html
   Although once there, not easy to find...
   13.0460-9031.2  Brake Pad Set, disc brake     0
      Trade Numbers: 20437, 609031
   Width: 89,9 mm, Height: 70,5 mm, Thickness/Strength: 19 mm, Wear Warning Contact: Prepared for wear indicator, Excl. wear warning contact, Brake System: ATE
AK1185
Alan Faulkner-Stevens
Hello Ian, If your car has AP front brakes they are the same as the CRS. These are quite unique and feature special thickness discs. A high quality road performance pad can be purchased from EBC brakes in Northampton. I have them on my CRS as do other CRS owners. Please e-mail me and I can find you all the information you need
   faulknerstevens@btinternet.com
   best wishes
   Alan
