front lower swivels
Started by SBB, April 29, 2008, 19:55:15
SBB
Any idea which car the lower bearings for the front lower swivels come from-trouble with the mot-my car is a 1997 mk4.?Thanks Richard Thompson
Hi Richard,
   I had a similar problem with my '91 MkIV last year. I was told that the part was possibly from a Saab and is no longer available. The chaps at Thunder road modified the lower wishbones to accept a current Saab part and all was fixed. I thought it was going to be a big problem and it turned out to be no big deal. The car is much better now that both front wheels point in the same direction[;)].
   It's probably worth a call to Thunder Road to check out what options you have.
   John.
wenzeh
Richard,
   Just purchased two lower swivels from Gerry Hawkridge - he has all parts you can imagine!  The suspension on my AK 1005 (1982) is MKIII and I am not sure if the parts had changed over time on later production cars.
   Previous owner had applied a strange part on my car and at the end the joint had almost 1 mm of movement!!!
   If I would know how to post pictures I could show you the old and new parts - if you are interest!
   Heinz
Heinz,
   Autokraft changed the parts totally. In our early MK IVs the axles are taken from a MK III. The track rod is pushed from below through the lower wishbone.
   Later, the track rod ends where taken from a Saab and were mounted as a complete part screwed to the lower wishbone. This was not a good solution since I heard of some people who lost these during driving because the screws were broken.
   Regards, Peter
