AC pedals
Started by French Frie, June 07, 2012, 21:17:20
French Frie
Ok, not a big deal, but in the same process to make the interior looking like I want, I installed AC engraved pedal to the Ford pedal box ...
   I ordered the parts from Finish Line, and the cast is quite rough... So I polished it, but more importantly, I milled the boss in order it 'll  can be inserted in the hole on the pedal (where the rubber was previously):
   I then glued them with a bicomposant metallic epoxy glue to the existing pedal (very strong!):
   Pleased with the result...
