AC Bristol ring and pinion
Started by Thomas Ellsworth, August 08, 2006, 16:36:01
Thomas Ellsworth
Does anyone know where I can locate either a very good 3.9 ring and pinion or if anyone is making them on the after market. What other cars was this ENV unit used on?
   Tom Ellsworth
Hi Tom
   ENV differential units were fitted to some of the larger upmarket Saloons of the 1940s and 1950s.
   I believe 1950s Daimler used 3.9 & 4.3 ENV units.    Caution many of the larger heavier Saloons used ratios of 4.5 even 4.7 & 4.9,  one person who could throw some light on the subject is Mike Mansergh, in Workington, Cumbria.  suggest you email him direct on...
   mike.mansergh@bt.com
   If you find a source of supply of either complete units or new old stock parts please keep us all informed as these units are as rare as hens teeth.  Good Luck !
   Keith L Lessiter
Thomas Ellsworth
Have looked into Daimler ENV units. Unfortunately they used 3.7 ratios not 3.9. It would work, but prefer the proper 3.9 so still looking.
