More new AC engine gaskets.
Started by 3andahalfpints, November 11, 2025, 14:38:21
3andahalfpints
I've added some more new gaskets to my e-store.
2 gaskets for the thermostat. As far as I know, these fit all the postwar AC engines.
Set of 3 inlet gaskets. I've modified the centre gasket by omitting the water slot which became redundant once triple SUs were fitted. The slot in the old gaskets, led to corrosion of the middle inlet stub pipe. Later CL to CLBN engines don't have have the slot in the cylinder-head anyway. If you have a vintage engine with a water-jacket on the inlet manifold, then you will have to cut the missing slot out. I can supply a drawing... or I can cut it out if you ask nicely :)
Thermo to stub pipe gasket:
https://ac2litre.com/store/index.php?main_page=product_info&cPath=14&products_id=302
Thermo to head gasket:
https://ac2litre.com/store/index.php?main_page=product_info&cPath=14&products_id=301
Inlet gasket set:
https://ac2litre.com/store/index.php?main_page=product_info&cPath=14&products_id=300
Ian
