HI just what are the 2 silencer things by the manifold and are they effective or restrictive?
Cheers Gary
Hi, well it seems that I am not the only one who has no idea as to the use of the 2 silencer type cans judging by the views and lack of response.
Still I am sure someone will let me know in due course.
On a two stroke engine they might be expansion chambers which have the effect of sucking out the exhaust gasses and thus pulling in the incoming mixture. I can't quite see how that would function on a four stroke! So no help from me.......
Hi Yes thats what I thought, it has been suggested that they are pre silencers, however not sure what that would be. Mainly I want to try and find out is whether they are restrictive or nor not. The AC engines Ace seems to have 6 branch manifolds without these so maybe not all that much use really. Still will keep on trying to find out before I consider a 6 branch manifold to improve things.
The story is that Charles Hurlock had a theory that noise went sideways and they were his solution to the problem. Mine are blanked off and it doesn't seem to make any difference, perhaps unsurprisingly.
It would be interesting to know what comparative testing AC did!
Apparently Rolls Royce had something similar which may have been the reason AC did it!
Hi Admin.
My thoughts were perhaps and expansion chamber type set up, but then I thought that going sideways and then back again would upset flow. May just take them off.
Does anyone do a suitable twin 3 into 2 type manifold for the 2 litre saloon or has anyone tried one.
I will do some testing re sound and MPG with and with out the twin cans, first.
Cheers Gary
The Vintage Engines had a cast iron pair of manifolds which probably had better gas flow, & did not have the side silencers!
Hi Robin
Cheers for that, however will probably go for 6 branch or twin 3 into 2 type banana bunch type.
Cheers gary
The manifold mounted silencers, are just that: Silencers. Each pulse of exhaust expands into the silencers, dissipating noise into the insulated chambers. As the pressure drops in the pipe, gases flow back out of the chambers. By having the silencers at right-angles to the pipe, and opposite each other, I believe it minimises the effect of reflected pressure pulses reaching the exhaust valves (the effect that Jam2 was referring to above). It needs to be minimised because those silencers are too close to the engine, and the manifold branches are unequal lengths. The down side to these silencers, is the large amount of heat released under the bonnet.
Hi 3.5 pints
Yep definitely gets some build up. I have acquired a set of cast manifolds with out the cans so I will be trying these to see what happens before working on a set of extractor type manifolds. Also need to lose the big bypass oil filter that is attached to the manifold for a full flow one mounted down low away from the heat.
Cheers G
Full flow filtering is certainly a wise move. I noted your mention of installing electronic ignition, as I know of an AC with the "123 Ignition" distributor (with great results). It will be interesting to monitor how well these perform. My wood frame drawings were used in the restoration of your AC in the 1990s. Sadly, I only discovered your AC lived near me, when it came up for sale this year! Best of luck.
Hi 3.5pts
Yes I have the full set and the original letter from you to the chap that carried it out. I also have read in great depth your website, very interesting and useful.
Yes will be going to full flow filter but need to work out what direction the flow is and how to loop the pipe that runs to the the top of the block into it. Also considering fitting an oil cooler into this.
So far the electronic ignition seems to be performing well covered some 160 miles sunday to and from brooklands and it appeared to run more smoothly, it certainly ticks over smoother.
Will see how fuel etc goes over a longer period.
Cheers Gary
The main oil outlet from the sump's filter body, is the one pointing to the right of the car, with a T-junction for the pressure gauge pipe. The main feed pipe then goes straight into the block to the main bearings. Full flow filters are inserted in place of this main feed pipe. On most installations I've seen, the 2 connections for the bypass filter were blanked off. On one engine, they had fitted a by-pass pipe, but I would have thought the lack of resistance, would cause too much oil to flow down it, instead of into the bearings.
Robin's AC Engine Project website describes a filter that incorporates a relief valve after the filter, to ensure that the correct supply pressure is maintained. This will need an extra pipe for surplus oil to return to the sump.
I haven't come across oil coolers on the 2 Litre, and am not sure if it would be needed?
There are plenty of electrical/electronic upgrades that one can consider: Electronic fuel pump, electronic control-box, and LED lamps including built-in flashing indicators.
Cheers for that. I did think that the one with the pressure gauge would probably be the feed, but was not sure. What exactly does the pipe to the top of the block do apart from running to the bypass filter, as I was thinking of replacing the pipe with out the bypass filter in line as it seem to run back to the pump housing anyway.
Re electronic bits and bobs oh no that what I love about the car its all nuts and bolts etc.
I did speak to robin about his oil filter but it seems to be for his new engine blocks only, he suggested Rod Briggs or get a remote filter housing from Mocal or the like. Now need to see what the thread is on the oil pipe.
Only thought of oil-cooler as read about it in the AC 2litre book tuning and improvement part.
Cheers again and as per website very helpful.
Evening Gary
Nobody has any idea what they are for!!
Mike Berrisford and myself have had a batch of manifold plates made up to make a free flow down pipe instead of the cast iron manifold and steel flexi one
I think I also have a starting handle if you are still looking for one
Mike Smith
Hi Mike
That sounds interesting, was thinking of similar lines re manifold plates but looking in engine bay not much room for free flow down pipes. Would be nice to pic of item and pipes. Will PM you re this and the starting handle.
Cheers Gary
The idea was originally patented by William Hurlock and AC (Acedes) Cars in 1936/37. The patent number is GB470786A - Auxiliary Silencers. Details of the patent can be found through the UK Patent Office search engine espacenet.
I imagine the boxes helped damp out noisy resonant frequencies. Whether the theory outlined in the patent would stand up to scrutiny against the current understanding of resonance in exhaust systems is doubtful.
As the boxes are branches off the exhaust system, rather than through boxes, it seems unlikely they would cause any resistance in the system. However, resonance in both intake and exhaust systems can aid, or hinder, the fluid flow rates. The impact these boxes have in that respect are not known to me.
In the 1950s, on our family Two-Litre, my father replaced the two auxiliary silencers with smaller diameter tubes of the same length as the originals. I can't recall if it made any difference but the replacement items were made of power station boiler tubing and lasted much longer!!
I have a vague recollection of replacements being made to original drawings about 15 years ago. Brian Eacott may be able to help.
Many thanks for info, however I am looking to improve the flow of the exhaust system. I have a couple of spare aux silencers on my shelf and a couple of original manifolds (one having been smoothed over to improve look), was going to use one to make a manifold flange but looks like mike may have already saved me the hassle.
As to the flow/pulse of the gasses I think the gasses exploding sideways and pulsing back so closed to what is a fairly restrictive manifold anyway does not help with free flowing exhaust. AC Aces use a free flow manifold which certainly improved performance in this respect.
This is a route that I will look at going if I can workout where to fit the down pipes in as the engine bay/ steering column is a bit tight for space. I believe that some owners have fitted them through the inner wing and run the pipe under the cat from there. Will need to research this.
Cheers Gary
