Would anyone have one of these clutch arms at all?
If you do PLEASE get in touch. Or do you know of another vehicle that uses the same part so I can hunt there too?
It is the arm that takes the plunger of the slave cylinder. (I have had to fabricate the plunger and I have done 2 so if anyone needs one shout. I also have a spare slave cylinder stay rod fabricated.)
Best wishes
Paul
Paul not sure if this will help but look at page 24 of the attached, it lists all the other vehicle that use the same slave cylinder so may point you in the right direction (or not).
https://irp-cdn.multiscreensite.com/94895fc8/files/uploaded/GIRLING%20APPLS%20NW.pdf (https://irp-cdn.multiscreensite.com/94895fc8/files/uploaded/GIRLING%20APPLS%20NW.pdf)
Cheers Gary
A lot of commercial vehicles in there:-)
Best
Paul
Yep those Aston's are a bit truck like😁
Do you still have the old saloon?
G
Yes I do Gary.
Best.
Do you want to shift it?
G
Not for a while Gary. Best. Paul
Paul
let me know when you do.
Cheers G
Will do. Best
